4 members (walter74, Phak1, PEB56er, 1 invisible), 129 guests, and 4 robots.
Topics128,090
Posts1,056,382
Members48,442
Gas Pumper
Gas Pumper
I am trying to figure out without draining the water out of my engine what the rear drain on our engines is sized. 1/4 NPT or 3/8 NPT. Depending on how I hold my head while staring at the outside of it, I could go either way. Anyone know for sure. I think they are the same for the 216/235/261 engines.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
1/4" NPT on all of them I've checked. The common sense way to check it is to try a tap in the hole- - - -or ask an engineer.
Gas Pumper
Gas Pumper
I did! smile
All of mine are sealed and have water in them. Otherwise I wouldn't have asked. Thanks!
Deve
The Think Tank
1/4" NPT, same as a drain cock in a radiator.
dg
Denny G
Sandwich, IL
Gas Pumper
Gas Pumper
That is a good way to remember it!
Deve
The Think Tank
