| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | Now I know (thanks to Tim my newly purchased engine is a 1955, does anyone know if it will bolt into my 1949 truck with a frozen 1954 engine in it? Will I need to weld in new motor mounts in a different location? Thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There were two different engines in 1955. Both mount the same. But you will have to modify the water pump if it is a '55 second series engine. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Just read the other thread. A first series engine should bolt in place with no problems. | | | | | Joined: Jul 2015 Posts: 18 New Guy | | New Guy Joined: Jul 2015 Posts: 18 | I had to replace the original 235 Loadmaster in my 49 model 4400 1 1/2T. I put in a 1956 car 235 and had to do the water pump mod. Also had to replace the pilot bushing for the transmission. The 56 car engine pilot bushing is different and won't fit the 49 trans input shaft. I re-used the 49 pilot by shaving a few thousandths off the outer diameter.
George
| | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | Thanks Guys.....can I post photos of the work done on the truck here? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are instructions at the lower left of this page.
Briefly: if you have a photo hosting account somewhere, they will have a way of giving you a "public" link to a specific photo. Copy that link and paste the link on a line in a post here. | | | | | Joined: Apr 2004 Posts: 5,069 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,069 | Billm,
Sure you can post LINKS to photos. We don't actually have the pictures here (as stated in the policy Tim referenced on the bottom left). But links - sure -- the more the better.
Peggy M
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Thanks Guys.....can I post photos of the work done on the truck here? A new forum has just opened called Project Journals. You might want to start a thread of your progress there. | | | | | Joined: Apr 2004 Posts: 5,069 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,069 | Actually, the best way to get into the Projects section (kinda like interning) is to start your "build / project thread" in the Engine forum. After you get to a certain point, John will have a chance to check it out.
We do hope to have more than just truck resto in that section. Right now, we are working out any bugs in the set up. So, starting in Engines will at least give you a start with some feedback and make it easy to move it to Projects when ready.
Peg
