6 members (TexasA&M48Truck, Charles in CA, MickeyP, Nick in Manitou, Ponchogl, 55shaker), 125 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#1132013 10/30/2015 4:23 AM
Can someone tell me how you set the timing on a 235? Mine pings under hard acceleration.
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years)
1966 Chevelle (owned 53 years)
Think of the vacuum advance unit as an arrow and the end pointing out away from the distributor as the feathers, and inside the distributor as the pointy end. Turning with the arrow advances the timing, going backwards retards it. So, back the timing off, toward feather end till the ping is barely heard under heavy acceleration. That will be ideal timing.
Joe
Thanks Joe
I would first change/clean the points, check for worn contact area on points where they contact the distributor cam, and set the gap at .018 inch, then follow Joe's excellent advice. I ran around in circles with a similar problem as yours and couldn't get rid of the ping without losing most of my horsepower. Turned out to be badly worn points where the plastic rides on the distributor cam.
Carl
Very good advice above, as usual, from Joe & Carl.
If you have (or if you buy) an inexpensive vacuum & fuel-pump pressure gauge/tester, here is a simple technique for adjusting timing and the carburetor.
