0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | what is the easiest way to put duels on the back of a 53 31oo with a flat bed. newer rear end, will not be carrying a load. root | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | With a flatbed where clearance is no problem, I would find a frame cutoff from a one ton cab and chassis. I would splice the two frames right behind the cab. The reason I would look for a cab and chassis is because dually pickups have a 10" winder rear. It doesn't particularly have to be a Chev. Your wheels aren't going to match the front at any way you go. I would install a brake proportioning valve. A newer rear will have better brakes and they will lock up on slick pavement. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Is this duel going to be with swords or pistols? Be sure to acquire a good set of "seconds" to assure the contest is held in accordance with the archaic rules of dueling! Jerry
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Thanks for the input crenwelge will check into it. But there always has to be a smart a** and we all know who. root | | |
