4 members (dwreills, Dennys28, Ponchogl, Hotrod Lincoln), 110 guests, and 2 robots.
Topics128,042
Posts1,055,518
Members48,424
#1131758 10/28/2015 9:19 PM
what is the easiest way to put duels on the back of a 53 31oo with a flat bed. newer rear end, will not be carrying a load. root
root #1131789 10/29/2015 12:24 AM
With a flatbed where clearance is no problem, I would find a frame cutoff from a one ton cab and chassis. I would splice the two frames right behind the cab. The reason I would look for a cab and chassis is because dually pickups have a 10" winder rear. It doesn't particularly have to be a Chev. Your wheels aren't going to match the front at any way you go. I would install a brake proportioning valve. A newer rear will have better brakes and they will lock up on slick pavement.
root #1131861 10/29/2015 2:47 PM
H Online: Content
Is this duel going to be with swords or pistols? Be sure to acquire a good set of "seconds" to assure the contest is held in accordance with the archaic rules of dueling!
root #1131930 10/29/2015 9:18 PM
Thanks for the input crenwelge will check into it. But there always has to be a smart a** and we all know who. root
