5 members (J Lucas, Jeff Ogden, Wickedbass, treegrower, DoubleB), 66 guests, and 1 robot.
Topics128,091
Posts1,056,033
Members48,433
I saw an article on this Structual Adhesive in one of the magazines I subscribe to.
Has anyone here used, or heard any negative or positive things about this product ?
Following is a little description of a product sold by Eastwood Co.
No Weld Panel Repair Kit
Item No. - 31102
With this economical and easy-to-use kit, you can carry out a wide variety of auto body repairs even if you don't have access to a welder. This comprehensive package provides the tools and materials needed to install metal repair panels securely-without welding. Panels are first flanged, then bonded with structural adhesive, and flush riveted. The result is a flat, repair surface requiring little or no filler. The panel adhesive eliminates any corrosion at the joint. No-weld panel repair kit contains dimpling pliers, 1" panel flanger, compression pliers, 20 panel holders, adhesive, and instr. Caulk gun required.
What are your thoughts?
Joe - (Buckeye Bowtie)
"Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100
1971 C-10
1939 Buick Century
Buckeye,
We've had a few discussions on this subject over the last couple of years. Do a search in just the Paint and Body Shop for "adhesive".
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
