9 members (MickeyP, TexasJim50, MRMEROTH11, 2-Ton, Southerntruck, Ponchogl, JW51, Shaffer's1950, 1 invisible),
117
Mod | | | Forums66 Topics128,132 Posts1,056,378 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11318 06/10/2003 6:19 AM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | Hey guys! we are about to move here pretty soon, but for now I am passing the time helping our next door neighbors son with a go-kart he is building. It is an 8 horsepower 19 cubic inch Horizontal shaft Briggs and Stratton. It has a Flow-Jet carburator on it. We have no idea how old the engine is, but here is an idea: it was origionally sold by Montgomery Ward, so it has to be at least 20 years old, because I have no idea when they went out of business. We have a catalog that you can order new parts out of, and it shows that you can get chrome piston rings for these engines. Should he use them? I know a lot of these small engines by B&S used chrome inserts in the cylinders, but can these be used with iron cylinders? Also, I am looking for sites that show how to do performance upgrades on these engines. Thanks guys!
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#11319 06/10/2003 2:09 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | |
#11320 06/10/2003 2:43 PM | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | MONTGOMERY WARD'S ONLY CLOSED DOWN JUST A FEW YEARS AGO. THOSE GUYS USED TO SELL EVVVVERYTHING.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
#11321 06/11/2003 7:23 AM | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | Check out these guys for cool race stuff for the B&S. Jegs Post the serial number off the engine, I have some tech information that may help identify it. | | |
#11322 06/11/2003 8:34 PM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | Serial: 190402 0652-02 730352310
Jonathan S. Keffer
#11323 06/11/2003 8:48 PM | | Anonymous Unregistered | | Anonymous Unregistered | easiest performance boost is to file about .005- .010 inches off of the exhaust valve stem (check it during a full rotation of the cam to make sure you don't take too much off). This will allow you to get the full mechanical compression rather than about 70% of full compression due to exhaust cam lobe profiling done for ease of starting. Also, you can do a few tricks with filing the key on the flywheel to advance the flywheel timing and creative mods to the points to advance the points timing 3 - 5 degrees to allow a little more pop. My company sponsored a racing lawn mower for a few years and the first one we built up for one of our employees to race - it was a lot of fun and you would be amazed at what a mower looks like running 30 mph into a corner spraying rocks and dirt everywhere as they pass on the inside trying to get the hole shot  | | |
#11324 06/11/2003 9:59 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | On some motors you can use an aluminum flywheel for reduced weight. Some B&S shops stock offset keys for changing ign timing. Aftermarket cams are available to slap the valves open for high RPM. You can also play with cam timing. Some ring sets feature low drag rings for higher RPM. Just don't use chrome rings in a chrome or plated cylinder. There are also aftermarket dippers and rods & high comp pistons.
have fun!
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#11325 06/12/2003 5:46 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Maybe you should put a B&S motor in your car, chip, then you know you won't have problems with the distributor. :rolleyes:
#11326 06/13/2003 5:58 AM | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | Sorry my book doesn't go that new. All I have is the alpabetical series engines. Joe | | |
#11327 06/13/2003 6:57 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | nitro......NITRO and a lot of timing! 40% 45degrees!!! BOOM BOOM!
YOU WILL NOT NEED A CARB IF YOU RUN METHONAL!! just a hose! | | |
