1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#1131373 10/26/2015 3:24 AM
I posted in the driveline section but it might get a little more help here. I'm trying to install power steering in a friends 62 chev half ton and was pretty nervous about trying to get the right box to work with the least mods. I talked to another friend with a 63 and he said he used a 73 blazer unit. so I have one ordered and waiting for it to come in. does anyone have any other tips or a better fit? I will also have a challenge getting the pump mounted since it has a small block V-8 in it with the old heavy horseshoe shaped front engine mount I think maybe from a bigger truck. so not any extra bolt holes in the front of the block to use. - I'll have to fabricate something to work with the engine mount. But if I can get the steering box in righ I'm sure it will work
I discovered this recently and thought it worth sharing. It a YouTube video on electric power steering. Very cool!
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Skelflyer #1131957 10/30/2015 12:21 AM
you
could install side mounts
what vintage is the engine. do you know whether or not it has the long or short water pump. this makes a difference in what pump and pulleys to use
you can use any chevy 2 whl dr steering box from 73 up to 88/89 and also from crewcabs and suburbans to 91, somewhere around 1980 theey change hose fittings from SAE to metric and that is not hard to rectify
this fellow makes a good steering box adaptor and you will need one to mount the later str box
http://www.67-72chevytrucks.com/vboard/showthread.php?t=332923. his email is in the first thread
alan grove(GOOGLE) make relocation pump brackets and sych
ron
thanks for the help- I did get the pump situation taken care of and this adapter idea is a great one for the gear box
