2 members (baldeagle, Oswald), 42 guests, and 10 robots.
Topics128,012
Posts1,055,316
Members48,419
#113134 10/27/2004 2:53 AM
Hello Iam having problems with my hood. All the way in the back is wiggleing like it need it a support or something. I notice about 12 inches from the back there is a support bracket but there is a gap of about 1/4 inch, doesn't that needs to be glue down to stop all the wiggleing that I am having...Once again thanks for all the help.
#113135 10/27/2004 3:56 AM
Wish I knew more and could help smile , but I'd bet someone is going to ask you what year/style of truck you've got.
51 Chevy 1/2 ton-Restored
46 GMC 1 1/2 ton-Farm Fresh
#113136 10/27/2004 2:40 PM
Anonymous
Unregistered
Anonymous
Unregistered
Seadog,
I have sent you a file that explains how to align a hood for the Advance Design series. I found this on another website some time back. Hope it helps.
#113137 10/28/2004 3:02 AM
Houston thanks a lot. My truck is a 49 and I think it needs some type of gasket or glue in the support, since when I hold it down like the left side it looks good. Houston what you send me will help me a lot since I also have to adjusted thanks
#113138 10/28/2004 5:01 AM
My 64 has a rubber type insulator between the inner hood brace and the hood. It was held in place by a glue of some sort. If you remove the brace you may find scraps that will give you an idea of what was there.
