| | | Forums66 Topics128,140 Posts1,056,776 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | This winter's project is to replace the brake wheel and master cylinders and shoes in the old truck. Have the front wheels off and what I would expect should be the wheel seal has no felt or anything that looks like a seal. Does anyone have an exploded view of the front bearing/seal assembly and/or what the wheel seal should look like? I am sure as I go along there will be more questions but for now will start with this.
1949 Chevy 4400 216
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GIJOE298, the original "seal" was a felt washer National p/n 5756, there is a replacement conventional type seal available National p/n 40973S $2.27 at RockAuto, only two left at that price, hope that helps. | | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | Thanks 3B! this helps a bunch. placed the order before there were gone.
1949 Chevy 4400 216
