5 members (DadsFirstPickup, 5 Window 9434, TUTS 59, Jon G, 1 invisible), 111 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
and got a a chevy 350 2 bolt main all for $225 dollars!!!!! the guy said it came out of a 77 chevy pickup and thats about all he knew, the engine code is V0330TKB VIN is C7F431843, and the casting number is 3970010. all I can find on it though is it was made between '76 and '79 for a chevy pickup producing 165 hp, what else can I find out about this engine?
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Have you pulled the oil pan yet? If that "TKB" suffix is on the machined pad at the front of the right cylinder bank, it's possible you've actually got a 4-bolt main engine. Most of the "T" suffix engines were 4 bolt.
When I bought a 54 model 235 engine and trans up in Indiana a couple of years ago, the guy GAVE me a 4-bolt 350 with one piston and rod assembly missing just to haul it off!
not yet, but I will definitly check it out now. I'll check tomorrow. this will be my first v8 rebuild, so I'll have a whole new host of questions to come!!
Indy wink
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
I always thought the 010 on the end of casting number normally means 4 bolt...the one in my 49 chassis is out of a 78 van its a 010 casting and a 4 bolt..............dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Good luck with that 350 Mater, keep us updated on the progress.
Allen
1974 Stingray Corvette
well, I just checked this morning and it is just a 2 bolt.but could I still do a vortec head swap on it? those were my plans, but would it be too much for this engine AND my poor boy's budget?
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
I've run plenty of 500+ HP 2 bolt engines on the circle tracks- - - -with cast crankshafts, no less! Coming off the turns at 3K RPM and winding up to 7K at the end of a straightaway on a 1/4 mile dirt track, and doing it twice a lap for 50 laps- - - -that's a tougher operating environment than any stovebolt engine swap will ever see. Go ahead and build it- - - -you won't be disappointed!
