2 members (Greg_H, 1 invisible),
384
Mod | | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | and got a a chevy 350 2 bolt main all for $225 dollars!!!!! the guy said it came out of a 77 chevy pickup and thats about all he knew, the engine code is V0330TKB VIN is C7F431843, and the casting number is 3970010. all I can find on it though is it was made between '76 and '79 for a chevy pickup producing 165 hp, what else can I find out about this engine?
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Have you pulled the oil pan yet? If that "TKB" suffix is on the machined pad at the front of the right cylinder bank, it's possible you've actually got a 4-bolt main engine. Most of the "T" suffix engines were 4 bolt.
When I bought a 54 model 235 engine and trans up in Indiana a couple of years ago, the guy GAVE me a 4-bolt 350 with one piston and rod assembly missing just to haul it off! Jerry
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | not yet, but I will definitly check it out now. I'll check tomorrow. this will be my first v8 rebuild, so I'll have a whole new host of questions to come!! Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | I always thought the 010 on the end of casting number normally means 4 bolt...the one in my 49 chassis is out of a 78 van its a 010 casting and a 4 bolt..............dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Good luck with that 350 Mater, keep us updated on the progress.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | well, I just checked this morning and it is just a 2 bolt.but could I still do a vortec head swap on it? those were my plans, but would it be too much for this engine AND my poor boy's budget?
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | I've run plenty of 500+ HP 2 bolt engines on the circle tracks- - - -with cast crankshafts, no less! Coming off the turns at 3K RPM and winding up to 7K at the end of a straightaway on a 1/4 mile dirt track, and doing it twice a lap for 50 laps- - - -that's a tougher operating environment than any stovebolt engine swap will ever see. Go ahead and build it- - - -you won't be disappointed! Jerry
