3 members (Goach2, Joe H, TexasA&M48Truck), 78 guests, and 3 robots.
Topics128,191
Posts1,057,224
Members48,465
My 1935 front doesn t have a hole for the cotter pin. Is
there a different method to lock the castle nut?
Check a little closer, maybe with a strong light and a magnifying glass- - - -I'll wager someone has forced the nut to turn and sheared the cotter pin off flush with the spindle. If there's a castle nut on the spindle, there has to be at least one hole for a pin. Later model spindles usually have two holes, slightly off-angled to each other so the nut can be turned a little and pinned without going another full slot on the castle nut.
There is a type of nut that has a lock nut attached. If you don't have a cotter pin hole that's just plugged up as mentioned email me I have one that requires no cotter pin that may fit
[email protected]
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
In my 1935 Chevrolet repair manual, on page 96 under "how to remove front wheels" it tells you to remove the cotter pin that locks the spindle nut in place. Maybe one of out members has the same year and can tell you the orientation of the hole. Sometimes using a strong cleaner or rust remover can create enough contrast to see the whole. If you had a magnet and some iron filings you might be able to find the hole using the same technique that is used on heads.
1951 1 Ton Completed
My bet? Someone removed the nut and left the cotter key in place...already posted above. The remains of the key are filling up the hole...but...my spindles are drilled for more than one cotter key...maybe, just maybe you can find the remains and push them out with a small punch. If not a "lock" nut will work.
Steve H
A locknut will not work because they need pressure to work and that is not the case here.
I would not trust a lock nut. They use cotter pins for a very good reason. No fun driving with only one front wheel.
Carl
If you can't find the original hole, why not drill another one? Larger trucks use a locking nut, but it is either 2 nuts or something like this http://www.macleanfoggcs.com/products/axilok/
We use Axilok on all of our wheel ends, but I don't think they make one small enough for your application.
