| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I restored a 66 step-side not just for fun but for work, We are window cleaners and need to have a rack on the truck. I am getting close to finishing and need a rack and was looking into stainless steel. But now I'm not real sure it is possible to put a rack on the truck with out bolting it to the side panels which I don't want to do. Has anyone built a rack for an older truck? | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | The rack I built for my step side is made of aluminum square tubing and slides down into the rear stake holes. It is a snug fit. The front part of the rack is a universal fit rack that clamps onto the drip rails around the cab. It worked great for transporting my canoe and is easily removable. Sold the step side years ago and still have the rack.
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | Hi Oldbolter
Do you have pictures of the rack | | |
