4 members (Otto Skorzeny, klhansen, Hotrod Lincoln, Peggy M), 108 guests, and 1 robot.
Topics128,050
Posts1,055,759
#11310 05/18/2003 12:18 AM
1 Offline
Hi, I just bought a 1950 1/2 chev that last ran around 94' and was wondering if I should have the gas tank cleaned and coated. What does every body else do in the situations? thanx eek
1950 1/2 ton 3 window
#11311 05/18/2003 6:20 AM
Y
Y Offline
First off, the gas that may be in there has got to go. I have not relined my truck yet because I have not moved to that part of the restoration, but I reline the tanks in all of my motorcycles and noticed a Huge difference in the frequency of fuel filter changes. I encourage it and will end up doing it soon too. smile
1954 Chevy 3100 235
2 Yamaha YSR50's
05 Silverado crew
00 Yamaha TT-R125 Supermoto
#11312 05/18/2003 7:18 AM
1 Offline
thanx for your help! grin
#11313 05/18/2003 5:52 PM
The thing to do is check the tank before you make a decision. My 52 sat for several years, and when I pulled the tank it was clean, other than a thin layer of varnish. No rust. If there is rust, I highly recommend using the POR-15 tank sealer, I've put it in one truck, two locomotives and a rototiller so far.
Fred
52 3600
69 C-10
