2 members (jmoore, Rusty Heaps),
91
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | Is there a source for nos or repro door hinges for a 1951 gmc 1/2 ton, and do you know what years will work? Are the 47-53 the same? And will chevy parts for the same years the same? Thanks in advance gang. | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | JimmyJeep, new hinges are not available, but rebuild bushings are available from most of the vendors (see links tab at the top of the page). Here is link about rebuilding the hinges: http://www.classictruckshop.com/door_hinge.asp
Winona 1949 3100 5 Window Deluxe Cab
| | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | JimmyJeep, new hingesare not available, but rebuild bushings are available from most of the vendors (see links tab at the top of the page). Here is link about rebuilding the hinges: http://www.classictruckshop.com/door_hinge.asp
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | I noticed that Jim Carters has used hinges. Be prepared to adjust them as I have found that they are not necesarily interchangable from one cab to another. Year to year though the design is identical. See the Chuck the Truck web page for some insight on one persons hinge experience. It has helped me with mine. | | |
