1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
my apache does not have power steering, all original 2 arm steering but there is a pretty bad creek sound from trying to turn the wheel any direction...any advice on where to look or what to change?!
H Online: Content
Look for dry bearings between the spindles and the front axle. Either the kingpin bushings are making the noise, or more likely the ball bearings that carry the vehicle weigh are worn out or corroded.
Riding in the Passing Lane
The king pins on these must be thouroly greased. If a fitting wont take grease remove the fitting & dig out the hole with an ice pick & solvent spray. Put in a new fitting & put high pressure grease to it while turning the wheels back & forth. When each fitting takes grease move the wheels back & forth & shoot them again. If you cant get grease through you will need to replace the kingpin & bushings. You will be amazed how much better the truck drives.
1972 Chevy c10 Cheyenne Super
Another place to look is the tie rods, especially if it dose it with no load on the wheels. I've seen tie rods do that on modern vehicles with sealed chassis. I do agree with Jerry and Wrenchbender, start at the kingpins.
Bill Burmeister
Agree with the comments regarding kingpins. I have found it helpful to remove weight from the kingpins while greasing them. Do this by jacking up the truck and supporting it from the frame or axle so the kingpins are not supporting the weight of the truck.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
