| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 45 Member | | Member Joined: Jan 2002 Posts: 45 | I have got my father's old 64 chev c10 at the body shop now. Finally got the guy to fix the the rusty crack near the passenger door under the door slid about 4 inches.
At first he thought he just cut and patch weld. But now i have been told the area is weak so they are going to fiberglass it.
Started the restoring over a year ago. It was fall and going to start to rain so and another season in the rainy weather would have nothing but rust...so i put it in the body shop. Over the year they kept it inside and now the paint and body work is completed.
As i said they are now fixing the rusted floor crack. What remains is to go through it mechanically... check brakes...clutch chatters in first gear...may need new clutch.
The truck runs pretty good with the original 292 engine even though it has over a 100k miles on it or more.
However back to the main question or issue what do you think about fiberglassing the rusted area of the floor...an area about 4x6 inches.
Your comments always appreciated
Starrider | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Fiberglass isn't going to add strength to area though. It is more moisture resistant than regular body filler. I guess it isn't going to hurt that much since weak area isn't around body mounts.  | | | | | | Anonymous Unregistered | | Anonymous Unregistered | It aint concours, but a lot of rigs are running around with a little kitty hair and resin that would otherwise sit parked waiting for someone to do the "real" patch. If done properly, it will add strength and stiffness. | | | | | Joined: Jan 2002 Posts: 45 Member | | Member Joined: Jan 2002 Posts: 45 | Whitelightning...well i guess will added some bondo over the patch.
A friend...welder...suggested i take a larger piece of tin cover the area however instead of welding it...drill holes and use bolts and nut with fender washers. I could still do that over the fiberglass and the bondo over the whole thing...not exactly the way you guys would do it...but what the heck...lol!
Starrider | | |
