1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 37 'Bolter | | 'Bolter Joined: Apr 2015 Posts: 37 | After struggling to get the brake cable thru the bracket on the frame I find out the plastic sheathing is to small and the clamp will not hold the cable in place. Any suggestions? I bought the cables thru classic parts. | | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | You don't say what year/model you have, but I replaced both of the emergency brake cables on my '49 3100 using replacements from Chevs of the 40's and had no issues. I had to spread the brackets a bit to get the cables in, but they clamped perfectly.
Greg Brown
| | | | | Joined: Apr 2015 Posts: 37 'Bolter | | 'Bolter Joined: Apr 2015 Posts: 37 | It's a 55 1/2 ton 1st gen. | | |
