9 members (Hotrod Lincoln, JoeDude, Shaffer's1950, Stovebolt48, Donf, 48jim1ton, gswbbc, frogfarmer, 1 invisible),
121
Mod | | | Forums66 Topics128,032 Posts1,055,516 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | would a 1962 chevy car or truck 235 came in chevy orange? just picked up a 59 with this engine in it and it is orange.......
thanks in advance.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. Only Passenger V8s and the Chevy II/Nova 153 4 cylinder and 194 6 cylinder were orange. A Passenger 235 would be blue, and the Truck version would blue/gray.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chevy orange was readily available in engine shops. It might have been used on any rebuilt engine.
What is the code that is pressed into the block just behind the distributor? That is the Engine Serial Number and it might help to ID the engine (car or truck, and model/series of vehicle).
How did you ID the year - 1962?
Depending on the year, the truck high-pressure 235 might have been gray, blue gray, or even green (supposedly). | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | the numbers stamped behind the dizzy are F0922J (I believe it is a zero, but could be an O in the number) and how I came to the conclusion that is a 62 235 is there are no captain's bars above the starter to indicate a 261 and the front mount is under the crank pulley/balancer and there are no side mounts cast into the block.
