2 members (Charles in CA, Woodcmiami), 151 guests, and 5 robots.
Topics128,266
Posts1,058,385
Members48,485
Howdy,
Looking for some help before I muck something up. My speedo's light bulb(s?) are burnt out and I would like to replace them. They don't seem to come off the back or twist out and not sure how they are accessed.
Any help would be much appreciated.
Cheers,
Sean
1953 GMC 9300 1/2 ton (Canadian)
If it is a task force truck you need to pull the socket from the cluster then you can twist the bulb out.
Ex Hall Monitor
Ex Hall Monitor
Every vehicle I've worked on from Chevy have the push in type of socket. They sometimes fit pretty tight but they should just pull straight out. They are held in place by friction fit provided by small spring action 'fingers'.
...pic... of an AD cluster.
G.M. Sea,
Is your truck a GMC or a Chevrolet?
What year truck?
Having an old person moment....I posted this thread oh so long ago and didn't think I did.....and ended up doing another post on the same thing just now....
yikes!
Thanks for the responses here, I have a 1953 GMC 1/2 ton Canadian, so basically its a Chevy truck with GMC badging. Its a 235 4 speed, goes slow and steady, likes to get hot but likes to go... fun truck, enjoy using it to do 'work'. Nothing like construction site stuff, but old truck stuff, like taking bottles to the depot, picking up supplies at the local hardware store or grocery shopping. Low intensity work for elderly vehicles.
Thanks again for the responses and sorry for the slow response, I am going to go and gingerly pop that bulb out.
Sean
