2 members (ShopRag, GradyB), 116 guests, and 1 robot.
Topics128,035
Posts1,055,564
#1129845 10/17/2015 2:22 AM
I recently put my 37 GMC on the road. The clutch did not engage smoothly and the shifty shook. I changed the pressure plate and clutch with the extra I had, same issue. I noticed while cranking the engine, the clutch petal went slightly up and down. I think I have a bent input shaft on the transmission or a bearing problem. Anyone have a similar issue?
Mike J 37 GMC
Do you have a pilot bearing? It would be pretty difficult to bend an input shaft
No, sleeve.
Mike J 37 GMC
Chatter while engaging the clutch is often caused by sloppy motor mounts. Check for collapsed or deteriorated rubber pads, particularly at the bellhousing mounts. One sneaky troubleshooting trick is to temporarily rig a piece of chain and a turnbuckle from the cylinder head to the driver's side frame rail and put just a little tension on it to prevent the engine from rocking as the clutch is engaged. If that cures or minimizes the problem, install new motor mounts.
