| | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | I have decided to weld in 'fatman's' hub to hub kit on a 46 chevy 3/4 ton and am wondering if anyone knows offhand what rear end would match up well with their kit? I would like something that would do well for just driving and will be replacing a 1989 Ford 3/4 ton that has a 8 lugs and 4.10 ratio. I am looking to have them [fatman] fabricate the kit but would like to have some idea of what to start looking for and match the bolt circle of either 4 1/2 or 4 3/4. I will likely find the rear end now and then have them make up the front end ..... thanks!
lane
sweetpealane
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | It depends what the track width of your front end is. Why not ask Fatman? I'm sure they have an idea. | | | | | Joined: Jul 2006 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 36 | The 1971-81 Camaro rear axle fits well under these trucks with the bolt pattern being 4 3/4 | | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | thanks for this info ..... I had heard that S-10 rear ends worked well too but thought I should ask here on the bolt. The guy I originally talked to at Fatman was reluctant to recommend one, supposedly to let customers sort it out for themselves.
lane
sweetpealane
