6 members (TexasJim50, stlcardinalsguy, Woodcmiami, klhansen, Hanks custodian, Wally / Montana), 64 guests, and 2 robots.
Topics128,059
Posts1,055,820
#1127619 10/02/2015 10:18 PM
I recently purchased a '64 C60 with 292, SM420, Hydrovac brakes, and two-speed rear axle. I'd really like to get the speedometer working. I have searched for information to no avail.
The speedometer cable routes as follows: Speedometer to small aluminum looking piece (inside firewall between pedals) out the cab to the transmission. The small aluminum piece has a wire terminal with no wire connected to it. I assume this is to work in conjunction with the two speed rear axle so when shifted the speed will read correctly.
Does anyone have a wiring diagram for this small unit? It looks to be original GM and bolted the firewall
The speedometer speed adaptor requires 12v to shift to HI range. Find the HI range wire going from the shifter switch to the electric shift motor on the rear and tap into it to power up the adaptor, that's it...the adaptor case is grounded to the fire wall.
If you follow the wiring from the gear shift lever to the rear you will likely find where the tap was originally done somewhere under the floor. Tap back in with a new wire and route it up to the adaptor.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike, thanks for the point in the right direction. However this truck has the vacuum actuated rear two speed axle and no switch or cable on the transmission shifter.
There is the remains of a cable coming off the original vacuum "switch" under the cab, so my axle remains in "High" all of the time.
Getting the rear axle to shift is also on my to do list. Any recommendations on the best way to accomplish this will be appreciated.
Crusing in the Passing Lane
Probably not ever need the low end of the 2 speed, so don't worry about it for now.
I wonder is someone in the trucks past wanted to add the electric adaptor after the vacuum one attached to the back of the speedometer went bad. All you would need is a switch on the dash with 12 volt keyed power for manual use...
Chevrolet always recomended trucks be parked in Low Range...had so oldtimers tell me the 2-speed rears could drop into neutral (between gears) and free wheel if the truck got bumped while parked. Hi Range is UP on the actuator on the rear housing and gravity could pull it down. I don't know it this is true or not, but I park mine in Low just in case it is.
If I had a truck that would be in HI forever, I would somehow lock the rear shift linkage back at the rear so it couldn't move. I would hate to hit a pothole and have it fall into Low Range while I was traveling the country side...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I plan on fixing the two speed rear soon as the worn 292 doesn't like to move the truck with the dump bed loaded.
I removed my instrument cluster and there isn't a vacuum switch on the speedometer. I looked at another '64 C60 with two speed rear today and it has the same aluminum device bolted to the inside fire wall behind the pedals and no vacuum switch on the rear of the speedometer. The funny thing is, there was not a wire hooked to this one either! This one also had only a cable with a knob going from the vacuum switch up to the transmission shifter, no electric switch to operate the speedometer device could be seen.
Did GM make shop manuals for 60-66 Medium Duty trucks? All I have found are for the Light Duty trucks.
It would be nice to see a picture of the part in question...
You need to start with the 1963 Truck Shop Manual (one book covers ALL trucks), that's the base line and then get the supplement for 1964 which will have new itens not found in the 63 book.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Good info here. I got lucky with mine and the speedometer works and I got the original manual with my 66. Good info in it but covers a lot of vehicles so is a bit vague in spots. Good luck and keep asking questions. Lots of good help here
