3 members (WICruiser, 2 invisible),
142
Mod | | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | Has anyone used Pelucid POR 15 as a surface coating on their bedwood? Know this stuff is pricy, but is it worth it? :confused: | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Brian - pricey rust-proofing paint for wood?? :confused:
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "Pelucid is a rock-hard, crystal-clear, non-porous single- component topcoat. Pelucid can be sprayed or brushed over painted or unpainted steel, fiberglass, or wood. Pelucid will not yellow and is not UV sensitive. It is strengthened by exposure to moisture and will cure to a rock-hard glossy coating that won't crack, chip, or peel. Pelucid is tough, yet flexible, and has excellent wear and abrasion resistance as well as very good chemical and corrosion resistance." | | | | | Joined: Nov 2003 Posts: 86 Member | | Member Joined: Nov 2003 Posts: 86 | tclederman, now let's see here... would you go with "Pelucid "? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | ad,
No, I would not use a new product until I hear some good experiences from a few people. I posted the description for those people who might want to know something about the product that is being discussed.
By the way, I consider myself a southerner but you do not need to call me mam.
Tim | | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | Exactly, tcelderman--wanted to know if anyone had used the product, and recommendations. Thanks.  | | | | | Joined: Nov 2003 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2003 Posts: 86 | Wood finishes for outdoor wood need to be flexable. In racing sail boats when wood is encapsulated with epoxy as with the W.E.S.T system(wood epoxy saturation technique) wood movement is always taken into account. Use an epoxy that is too hard and the wood "checks" or cracks even when it's covered with fiberglass. My only concern with the por 15 paint would be it's ability to expand and contract with the wood movement. This is a two edge sword. Hard finishes resist scratches but don't move, flexable finishes move but scratch more easily. My choice for bed paint would be the original tar based for a black bed and a marine grade varnish for a clear coat. Both require periodic refinishing because of scratches and that's why the metal strips were designed to be higher than the wood and therefore take the majority of the scratches. Put as hard a finish as possible on the metal.
IMO John Atherton Wichita Forest Woodworks
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Let's put this into perspective...My bedwood was original to the truck, only 2 of the 9 boards rotted through after 50 years of no care at all. If you show, you want to do what they did at the factory, if you haul stuff, if it never is going to see the inside of a garage, I'm sure you want weather protection. The summer I stepped through a bedboard while at the recycling facility I decided that after 52 years the old girl deserved a new bed. I used found wood from a construction site (I don't call 'dumpster diving' stealing) and milled it on my home table saw to the correct dimensions for a '49 bed. I then painted the underside with a coat of Kilz as primer, then 2 coats of white housepaint. I wanted increased visibility when working underneath. I re-used the metal strips and replaced all the bolts with galvanized. I made my own bed blocks and protected them with a couple coats of housepaint. On the topside it actually came out too nice for me, I just used a pint of satin polyurethane until the can ran out. Cosmo\'s eight dollar bed wood
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | Thanks for all the reply's, and Cosmo, DARN NICE bed you have there!  My plans are the Mar-K bed (Oak) with polished stainless steel rails. I have a friend that recommended this sealer, and was going to use it when he installs a new bed in his '57 3200. Just wanted to see if anyone out there had used this product yet--anyone? :confused: | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Cosmo, Nice wood finish. Dumpster diving? Will this sport be seen in the upcoming olympics? Have you qualified yet?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
