3 members (GIJOE298, Peggy M, 1 invisible),
123
Mod | | | Forums66 Topics128,078 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | Hi I am haveing trouble with the gas gauge on my 41 Chevy, the needle will move between empty and below empty, but won't go any farther even though the tank is full. It's a twelve volt system and the gauge and sending unit are both brand new, can anyone help ? Thanks, Ian | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Gas gauge problems are usually related to one of two causes; the float isn't working right because it's flooded or soaked with gas or the ground isn't working well.
You say you replaced the sending unit. That should have included the float, so I would look for grounding problems.
One way to test the gauge is to remove it from the tank, ground the flange properly and then move the float arm up and down. The gauge should respond properly. If it does, the problem is likely the ground on the tank. One way to solve the problem is to run a ground wire from one of the flange mounting screws to a good ground on the frame. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you remove the sender wire from the gauge, it should register full. If you then put a ground on the sender connector at the gauge, it should register empty. When you went to 12 volts, did you do anything for the change in voltage? If you didn't, you may have a burned out gauge. | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | I replace the gauge and sending unit, both new items are 12 volt | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | The float that came with the new sending unit had a brass bubble sort of float on it, I will try what you said about the ground wire. Thanks for your help! | | | | | Joined: Sep 2015 Posts: 11 New Guy | | New Guy Joined: Sep 2015 Posts: 11 | i just hooked up my ampmeter and when i started the engine itwent to the full left discharge so i swaped the wires it went to normal charge rate, so if nothing else works you might have the wires crossed on the gauge. | | | | | Joined: Apr 2014 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2014 Posts: 33 | I'm kinda having the same problem with a '53 GMC. I put a new sending unit in but the gauge reads full (tank is 1/2 full). I tried running a jumper to the unit and grounding the flange like baldeagle said but when I move the float, the gauge needle moves from over full down to full. I wait to hear if you resolved your problem and what you did. Someone told me the sending unit and gauge might be mismatched. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | ff171,
Do you have a 6v positive ground electrical system?
Do you have an original sender and original gauge? | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | I've tried that and it just moved between below empty and empty. The gauge is a new 12v gauge. | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | Ok I'll look and see if my wires are crossed too, thanks! | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | Mine is just playing between empty and below empty, I'm gonna try what baldeagle said first then what the others said, I'll let you know what works. Let me know about your gmc! You might figure it out before me! | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | It's converted to 12v and has a new 12v gauge and new sending unit. | | | | | Joined: Apr 2014 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2014 Posts: 33 | ff171,
Do you have an original sender and original gauge? Mine is 12V negative ground and the gauge is a round one bolted on below the dash by the previous owner. The sender is a repo from the classic car parts vendor. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | GM up to 1964 - 0-30 Ohms GM 1965-1997 - 0-90 Ohms
The resistance of the sender should match the resistance of the gauge. | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | | | |
