I recently bought a '36 Chevy pickup and the previous owner had modified the steering back in the '80's by installing what I believe may be a Vega steering box.
The install was probably okay but I would prefer to return to something similar to the original configuration.
I have seen on these forums were a mid- 80's Toyota 4X4 power steering box was used. This is the direction I want to go but here is my problem.
I've located an upgraded box available at "CPP", what I need to find out is what length of pitman arm should I use and can I still use the original drag link (I will probably upgrade the drag link portion to newer style swivel ends).
I don't have the original pitman arm and can't seem to find the length of the original.
Thanks in advance!
