| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | I just started testing out my '54 3800 and it seems that when I put it in 3rd gear it goes in and then there's a loud "CLICK" and it seems to lose power or slows down but seems to stay in 3rd gear. What could this be?
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
| | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | I've driven it a few more times and the problem doesn't seem to happen. I'm not sure what that could've been
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | I would take a close look at the brake shoes. If one is not properly seated it might be "wedging" against the drum(loss of power). A bad or broken spring is all it would take.
Steve H
