4 members (Otto Skorzeny, Tiny, 2 invisible), 100 guests, and 4 robots.
Topics128,142
Posts1,056,478
Members48,441
#1128971 10/11/2015 3:20 PM
I was installing new taperd wheel bearings and seals in my 1950 3100. The inner bearing has a collar extending in twords the spindle that the seal rides on. The seal is flat. When installing the seal it is bottoming out on the bearing before the seal can be taped all the way into the hub. The seal seems like it will fall out. Unfortunately I bought this bearing kit over a year ago so I can't return it. I was looking in the Filling Station catalog and their kit mentions a modified seal. I wonder if that what I need. Any body else run into this problem?
The seal fits the hub(outside) and the spindle(inside). Stock seal should work fine. Keeping the grease in the hub and bearing. The type of bearing won't matter much unless it is too tall in the hub. Use your finger to feel the bearing sets all the way down to the step. If you can feel a gap, you need to seat it all the way to the seat. Compare the seal outer lip to a stock seal. They should be very close to the same height.
Steve H
