| | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 4 New Guy | | New Guy Joined: Oct 2015 Posts: 4 | I'm looking at buying this truck. From the title it says it's a 1956 Chevy 6400. The VIN #V6B56S024625. I don't know all the lingo used to classify these things. I want to know what size it is (2ton?), and if I'm wasting my time starting a project with this truck. Its in good shape. Runs and drives fine. One owner truck. I'm wanting to bag it and do a diesel swap. Preferably Cummins. Any input would help. | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | If you use our VIN buster - http://www.stovebolt.com/techtips/vin/vinbuster.html - you'll find out that the truck is a 2 Ton '56 154 inch built in St. Louis, MO. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Try just driving it first, then figure out what to do or not to do with it. I my experience driving and using the truck like it is for a good while gives a much better perspective on what is important to you and what might be necessary, and likewise, not necessary.
Grigg | | | | | Joined: Oct 2015 Posts: 4 New Guy | | New Guy Joined: Oct 2015 Posts: 4 | Ok thanks. I figured the information was somewhere buried in this site but when you're new to it it's a bit overwhelming. I know for sure I want to bag it and do a 12v Cummins swap. I've had a few people say to just buy a dodge dually and put the 56 cab on the dually frame, but then its not the same. I want the original truck. That's what makes it different. I just assumed there were a few guys in here that would know whether or not this model would be a good platform to start with. Thanks again guys. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I can't help with the diesel swap other than to say, get the tape measure out and see if the Cummins will fit. Is the existing motor a 6 or 8 cylinder? Mike B
| | | | | Joined: Oct 2015 Posts: 7 New Guy | | New Guy Joined: Oct 2015 Posts: 7 | Interested to see how that turns out. I think your right about dropping the motor and trans in the old truck. If your truck has a dump you will need to locate a pto output trans. Good luck and keep us posted | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Dropping it, bagging it, doing a diesel swap ! It's never going to be original again after that, so why not put it on a later chassis. A lot less work. It's going to be a non original custom, either way you put it. | | | | | Joined: Oct 2015 Posts: 4 New Guy | | New Guy Joined: Oct 2015 Posts: 4 | Thanks for all the input guys. The original engine is a V8. I think it's commonly referred to as an RPO or something like that. I may be completely off. Of course the truck won't be original after its chopped, bagged, and blowing black smoke, but I'm not wanting original. I want all the original body and frame. There is tons of 3/4 ton dually framed bagged trucks out there so that wouldn't really turn any heads. I haven't seen many in the "big bolt" format! Haha. That name alone is just cool to me. But thanks again. You guys have been a lot of help. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2015 Posts: 4 New Guy | | New Guy Joined: Oct 2015 Posts: 4 | | | |
