7 members (rfs56trk, Gray_Ghost, Wally / Montana, walter74, MRMEROTH11, David Bush, 1 invisible),
67
Mod | | | Forums66 Topics128,056 Posts1,055,803 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | http://www.pbase.com/dennygraham/image/161524394Ok, heared a bunch of guesses as to how the rod got bent. So I'm gonna open it up to the masses and see what else might pop up. No contact at top of piston and no loose objects in the cylinder. One guess, probably the only one that makes any sense is hydraulic lock, possibly from water getting into the cylinder thru an open valve. This was a problem with radial or inverted aircraft engines due to oil or fuel draining into the lower or inverted cylinders. Any other guesses? dg
Denny G Sandwich, IL
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Bent many a rod in the old flathead Ford V8's as they were prone to cracking and filling cylinders with coolant. When they wouldn't turn over the first thing done was to hook a chain on them and drag them off. Many times once they turned over and started they ran terrible---a sure sign of a bent rod. Often if revved high the bent rod would go bye-bye.
Evan
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | I had a one time issue with the bolts coming loose on the rocker arm supports. Driving home the engine started to stumble and cough through the carb. Later inspection found an exhaust valve that was not opening(the rocker arm never touched it) the pressure on every other rotation was almost enough to stop a truck still in motion. When the intake opened, not a lot but some, it would vent through the intake. Then the next time around, a new charge would fire and be trapped. Was harder to find than you might think. If it had gone on when I was driving faster, well I think I might have seen the same thing.
Steve H
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | That's almost got to be a hydraulic lock situation, combined with an effort to tow-start the engine. Be sure and check that cylinder for cracks, either with dye penetrant or magnaflux- - - -the cylinder walls are usually weaker than the rods, particularly on a 261 since the rods have a heavier cross-section and a bigger wrist pin. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | When this rod bent Evan, it turned over 1/2 revolution and stopped dead. Rod would not clear ether side of the block.
Intake valve on this engine is stuck open Steve, if any thing it would have been a free running No.1 cylinder.
My first thought Jerry, that is, that it had to do damage to the cylinder wall and or the block where it locked up or possibly to the web. But short of burning out the block and Magnafluxing it, it appears solid. I ran a stone hone thru the cylinder to clean it up and it appears good. Again, just a visual but I've a friend that says he's got a Magnaflux setup. Will check it out when I get it cleaned up. Was a little worried that the crank could have been bent also but it turns freely, which is a good sign. Hydraulic lock is about the only thing that it could possibly be. When I didn't see any visual sign of a hole in the block I picked up a new rod. Now I have to find a standard piston. Shouldn't be to hard as lots of guys have had them over bored. Only problem is most of the guys don't get the old parts back from the machine shop, who just toss the old pistons in the scrap barrel. Got the bore gauge out but it was to late to set up so I'll check it out tomorrow and see just how much wears there is. No ridge to speak of, just appears to be a little carbon ring in there. dg
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Wow, Denny, that rod REALLY bent. I guess my old flathead rods would be more accurately described as bowed.
Evan
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Denny, i have 6 used 261 pistons. I will check tomorrow to make sure they are standard. You can have them for the postage. Mtneermike
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | a new charge would fire and be trapped
It's trapped in the same way that a normal fill is trapped, except it contributes nothing to the crank motion. The piston goes down no matter what. If both valves are closed you have... a modern drop-some-cylinders engine. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | PM'ed you Mike, don't want to buy, sell or trade anything like that here. You know how it's moderated. Thanks
dg
| | | | | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | My guess would be it fired on the compression stroke before tdc. Maybe a cross fire, number 4 cylinder and number 1 fired at the same time. I would think number 4 fired in order and at the same time a spark jump to number 1 . Jbennett | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Think I'm goin' with Jerry's guess, hydro-lock and they tried pushing it. Big truck like a 6000 series would have a lot of weight behind it for plenty of traction and in a low gear it could put a lot of load on the rod if the cylinder had just a few ounces of water in it.
dg
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Cylinder combustion pressure doesn't bend rods. | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | A bench vice and a 3 foot long pipe wouldn't bend a rod like that! I can hear "Grampaw" now. "We'll break her loose or break her apart!" "Now get behind the wheel and hang on."
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | I reconditioned a connecting rod once for an 855 cubic inch Cummins engine that had enough twist in the I beam section that the wrist pin bushing boring job went all the way through the bronze facing and took out part of the steel backing. Now a Cummins rod is 12" on center between the wrist pin and the rod journal, the wrist pin is a 2" diameter piece of solid, hardened steel, and each rod weighs about 15 pounds! I'm guessing that one got twisted by an overdose of starting fluid and a little bit of water in a cylinder. Jerry
