9 members (KEVINSKI, Sjm, tclederman, Oswald, Cosmo, Otto Skorzeny, mick53, 2 invisible),
145
Mod | | | Forums66 Topics128,260 Posts1,058,288 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Cant remember how the steering mast/column bolts to the box. Does the hole and clip for the horn wire face up, down, right or left?
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** The horn wire on my 52 comes out of the column at the 1:00 o-clock position. On 3 speed column shift there is another hole or indention for positioning the shifter box.** | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Thanks - so does everyone have the horn wire at the 1:00 o'clock position on their 4 speed columns?
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Mine is at about 1:00 O-clock. It could I guess be in one of 4 locations...up and to the passenger side? It would look like the tube could be mounted in 4 locations, from the picture in the book: http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0906.htmFour bolts and four locations...my best guess? Horn wire up. I think you will only get one mounting with that wire "up".
Steve H
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The horn wire should come out the top of the mast jacket in it's stock position. Seems like the most logical place to put the wire to keep it from being kicked. http://www.pbase.com/dennygraham/image/161545087dg
Denny G Sandwich, IL
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | |
