7 members (Jon G, Wayne67vert, KEVINSKI, 50Chevy3100, 1955 1 Series, sron48, 1 invisible),
46
8
Mod | | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2002 Posts: 17 Member | | Member Joined: May 2002 Posts: 17 | I'm finally getting to a point where I get to start primering my truck but the problem that exists is it is now winter here in Utah. I need to heat a non heated shop up to 70 degrees so I can spray the primer. I was just thinking of going to the rental store and renting one of those construction heaters? Will this work, any suggestions or people that had the same problem? Thanks for the help as always. Glad you guys are here | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 57Chevy,
Heating and ventilation need to be considered. Of course, if you provide adequate ventilation, you will need a larger heating capacity. Room ventilation is important even if you wear a respirator suit.
I will be interested in seeing the advice you receive on this question. I usually wait until spring before taking on a large paint job in my unheated garage. I have ability to use electric space heat at marginal temperatures but my exhaust fan (from Grainger's) turns over the air in my garage every few minutes.
Tim | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | The one thing you want to remember is that spraying near ANY open flame is a big nono. So, you can't have any heat like that unless you turn it off before you spray. Also be careful about water heaters and other pilot lights that might be in the garage. BOOM!
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | ditto on the paint fumes and ignition sources. I remember as a kid my nieghbors owned a fab shop in town and while he was primering a steel framework an employee at the other end of the shop was grinding. Kaboom . . . instant inferno.
Husband and wife died of severe burns within 3 days of the accident. Volatile fumes are dangerous and you need to take care to evacuate them and remove all sources of ignition. Painting in cold weather is simply not an easy thing to pull off.
Warm the room and body panels up and then shut the heater off. Use low temp solvents and allow plenty of time for the primer to flash before recoating. Have an exhaust fan in a window blowing out. This will pull air in from outside to clear the fumes before starting the heater back up again. | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | 57 Chevy: I agree with Tim man it's cold here in In. got a heated shop and I'm still waiting for spring. Let alone fire hauzard (ret. firefighter) I worry about ventilation. I've ate so much smoke I'll have to put O2 bottle behind 59 seat. popcorn3023 | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | For repair garages in general, by electrial code, nothing that could create a spark is allowed below 18 inches, that's where gasoline fumes collect keep that in mind also, especially on old trucks with vented fuel caps. There is far more to the code than that and the amount of air exchange is a factor especially in a drafy barn, but are paint solvent fumes lighter than air? I once went to a body shop for some advise, a floor mounted gas furnace was running 10 feet from a guy spraying a panel. | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | All paint solvent fumes are heavier than air. About the only vapors in a shop you would find lighter than air would be acetylene and natural gas. But they're still explosion hazards. HLW
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | so basically you just want to use heat lamps have a couple of large fans for good air movment and make sure you dont have any open flames have you ever thought about rolling on your primer instead of spray?
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
