8 members (dt235sd, Lonnie, Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 2 invisible),
193
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 3 New Guy | | New Guy Joined: Oct 2015 Posts: 3 | I want to buy a rebuilt shifter box assembly for 1954 chevy 3100 1/2 ton.
I have looked everywhere. Anyone know who has one? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We rebuild ones for the ones we restore. About the only wear places are the round shoulder on the lower lever and the hole it turns in at the bottom of the case plus the slots in the shift levers. The selector tang can also wear. Some tig and mig welding plus a little time on the Bridgeport and lathe will make them new again. We don't do outside machine work but any machine job shop can easily do this. If one of the computer gurus would program a 3D printer to make the patterns for the case halves, upper and lower, then the mold and casting would be very simple I'd think. I think the rubber dust boot is available and springs can be bought by diameter and wire size. With all this said, 99% of the time we can find one in near new condition which is way better for the customer.
Evan
