| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 5 New Guy | | New Guy Joined: Oct 2015 Posts: 5 | Hello everyone! I'm new to this forum and to old trucks. I'm not even sure I'm in the right area for this question but here it goes. I just picked up a 1938 Chevy truck with a stake bed on it. Can I put a regular bed on in replacement of the stake bed? Will the wheel wells line up? Thank you for any input. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | As in previous posts today, I would give Mar-K a call if more info here is not forthcoming. Just Google them.
Drew
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | What size truck? Most trucks in the 1/2-3/4-1-ton range have frames that will accept a stake or conventional beds with corresponding install hardware.
| | | | | Joined: Oct 2015 Posts: 5 New Guy | | New Guy Joined: Oct 2015 Posts: 5 | It is a 1/2 ton. I have been doing tons of homework on this and found a wide variety of beds. Was just afraid of spending $1500 to $2000 on a bed that the wheel wells won't line up. Thank you for your input. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Check out the information package for your vehicle HERE for measurements to verify if the stock box will fit your truck | | | | | Joined: May 2011 Posts: 64 'Bolter | | 'Bolter Joined: May 2011 Posts: 64 | | | |
