| | | Forums66 Topics128,005 Posts1,055,264 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Where does the ground end of the Negative Battery Cable on a 1946 PU attach ? Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Sput, Thanks for the pictorial reference. Top of the transmission it is! Harold
Harold Is a restoration ever finished? | | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | There is a bolt on the 3 speed transmission provided for only this purpose. It is located near the tail end of the transmission opposite from the speedometer gear. | | |
