Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Hotrod Lincoln, Gdads51, Bill Hanlon), 115 guests, and 2 robots.
Topics128,286
Posts1,058,583
Members48,492
Fox
Offline
How wide is a 67-70 1/2 rear end from hub face to hub face? Considering this rear as a swap for my 50 1/2 ton. What ratios were available in them?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Not sure on the numbers but I do know its to wide. Look for a S-10 4X4 rear end.
I used a rear end from a 1967 half ton in my 54 GMC 9300 with 15 x 8 Blazer wheels and 225/75 x 15 tires and they tuck in real good. Gear ratio of 3:73 and t-5 trans makes for nice cruising. I can send a pic if you like- [email protected]
1954 GMC 9314 - 261 t5
I have a 12 bolt with 3.08 gears from a truck of that vintage and it fits without issue with stock 16" rims on my '50. It may be a bit wider than stock, but there is plenty of room for it.
Carl
Fox
Offline
Thanks fellas
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Suspension Measurements
REAR SUSPENSION:
The following is a general list of rear ends and their dimensions to help narrow the search for a possible candidate to replace the torque tube rear end or just get a better set of gears for highway driving.
Advance Design Trucks seem to be using rear ends with widths ranging from 58"- 62". I'm not sure of the Task Force width ranges at this time.
Contributing information were Bob Welch, J Forbes and various locations throughout the Web and Automotive Magazines.
Rear Axle Measurements
MEASURED ACROSS WHEEL MOUNTING SURFACE
56 1/2" 71-77 Ford Maverick 8",
57" 71-74 V-8 Mavericks 8", All '75-77 6's & 8's Maverick 5 Lug 8", 49-51 Ford, 57-59 Ford 9"
57 1/4" 64 1/2 - 65 Mustang
58" 78-88 Mid sized GM Car, Malibu/Monte Carlo (82 up Metric Studs), 80 Granada & Lincoln Versailles,
67-70 Mustang/Cougar/Fairlane, Regal with 10 bolt axle, S-10 P.U., 65-67 Nova
58 1/2 " Ford Grenada
59" 68-83 Corvette
60" 55-64 Chevy Car, 67-69 Camaro, 64-67 Chevelle, 68-74 Nova, 71-73 Mustang/Cougar, 84-95 Corvette
60-61" 64-69 1/2 ton 2wd Chevy/ Some GMC 6 lug rear end 12 bolt Coil spring set up Possible gear ratio's 3.70
62" 64-77 Chevelle, 73-76 Torino, 89 Trans Am,
70 2wd 6 lug rear end 12 bolt Possible gear ratio's 3:08, 3:40, 3:73
70-81 4wd 6 lug reared ...............................................................
71- Newer 2wd trucks use a 5 on 5 lug pattern
71-76 Full Size Cars " "" "" "
60" 60's GMC and some Chevy's Dana 44 or Dana 60 with leaf springs 6 lug, Gear ratio's 3.21 to 3.92. GMC V-6 used a 3.21 Dana 44 used a standard chevy 1310 yoke, Dana 60 used the heavy duty yoke which takes the larger 1350 yoke.
Approximate rear end widths measured from backing plate to backing plate.
Add Width to compensate for drums as follows:
4" - 5" for small cars 5" - 6" for intermediate cars 6" - 8" for large cars
48" - 49" 50" - 51" 52" - 53"
'71 Colt
'72 Cricket
'72-75 Datsun Pickup
'72-73 Mazda '65 Ram American
'74 Valiant '28-40 Ford , '57 - 59 Ford
'62 Buick Skylark, '67 Chevrolet Six
'67 Mustang Six , '68 AMX
'69 Javelin Six , '70 dodge
'70 Duster , '71-77 Maverick
'71 Comet , '71- 72 Pinto
54" -55" 56" -57" 58" - 59"
'39 -48 Chevrolet, '68 GTO
'41 -48 Ford, '68-72 Chevelle
'55 -57 Chevrolet, 68-69 Fair lane 6 or 8
'66 Falcon, '69 Chevrolet
'67 Mustang V-8, '69 Firebird
'69 Cougar, '71 -73 Nova
'73 Ventura, '73 Mustang '36 Plymouth, '54-56 Ford Pickup
'67 Lincoln, '69 Dodge
'69 Dodge Van, '71 Torino
'72 Cougar, '74 Pontiac '49 Plymouth, '61 Chevrolet Impala
'65 Cadillac, '66 Buick Wildcat
'66-67 Chevrolet Big Car, '72 Charger
'69 Oldsmobile 88, '72 Chrysler
'72-73 Torino
STOCK CENTER TO CENTER SPRING PERCH DISTANCE
25" 39" 42" 42 1/2
'68 - 72 Chevelle '71 Colt
'73 Mazda '68 -71 Fairlane/Torino
'49-51 Ford '69 Chevrolet
'69 Nova
'71 - 72 Pinto
'73 Ventura
43" 43 1/2" 44" 46 1/4"
'65 Ram American
'64 1/2-'65 Mustang
'67 Mustang
'70's Ford Grenada
'69 Firebird
'70 Dodge '71-77 Maverick
'70 Duster
'70 Nova
'71 Comet
'72 Dart
'72 Cougar
'74 Valiant '57 Ford
'67 Chevrolet Six
'68 AMX
'69 Javelin Six '69 Dodge
47 1/2" 48" 51" 57 1/2"
'39 -48 Chevrolet
'67 Chevrolet big car
'72 Charger
'72 Chrysler '69 Dodge Van
'69 Ford Van '67 Lincoln
BACK TO TOP OF PAGE
________________________________________
The following list of extensive information was contributed by R. Welch:
Original Vehicles
Rear Suspension Width (Flange to Flange)
Year Classic Vehicles Width
26-39 Plymouth-Dodge car/pick up 56-58"
40-52 Plymouth-Dodge car 60-62"
26-39 Chrysler/DeSoto Car 60"
Most Early Mopar's 56-62"
25-39 Chevy Car 56-58"
26-46 Chevy Truck 56-58"
40-48 Chevy Car 58-60"
49-54 Chevy Car 58-60"
47-54 & 55 1st Series Chevy Truck 60-62"
Most Early Buick,Olds, Pontiac 58-61"
28-31 Ford Car/Pickup 57 1/2"
32 & 33-34 Ford Car/Pickup 56 1/2"
35-48 Ford Car 57-60"
35-41 Ford Pickup 56-60"
49-58 Ford Car 57-58"
49-56 Mercury 57-58"
49-51 Mercury 61"
64 Falcon 58"
67 Cougar 60"
55-59 Chevy Pickup 62"
Donor Vehicles Front and Rear
Year Classic Vehicles Width Front Width Rear
74-79 Ford Mustang II/Pinto & Mercury Capri/Bobcat 55 ½" 55 ½"
71-77 Ford Maverick with 8" axle 56 ½"
75-80 Ford Granada with 8" axle 57 ½"
64-66 Mustang 57"
67-71 Mustang 59"
72-73 Mustang 60"
67-69 , & 60" Camaro 60"
64-67 Chevelle 60"
55-64 Chevy car 60"
65-67 Nova 58"
68-72 Nova 60" 60"
78 & up Monte Carlo, Regal, etc. with 10 bolt axle 58" 58"
68-72 Chevelle with 10 bolt axle 61 ½"
89 Trans AM (Disc brake) 62"
76-80 Camaro/Firebird 61 ½" 60 ½"
68-83 Corvette 58 ½" 59 ½"
84-95 Corvette 59 ½" 60 ½"
Early 70's "A" body (Dart/Duster) with V8&3/4 axle 58"
"E" Body (Cuda) with V8&3/4 axle 58"
Dodge Dart 59" 55 ½"
Plymouth Volare & Dodge Aspen 61" 60 ½"
71 Blazer (6 lug) 63 ¾"
75-78 Granada 9" (43" perch to perch) 52 ¼"
75-78 Maverick 9" (43" perch to perch) 56 ¼"
81-87 Olds Cutlass 58 ½"
FRONT SUSPENSION INFORMATION
Track Width of Popular Donor Car Clips
Manufacture Model Years Track Front/Rear Curb Weight
Chevrolet Nova 68-74 59.8-59.6 3,770
Buick Apollo 68-74 59.1-58.8 3760
Pontiac GTO 68-74 59.9-59.6 3880
Chevrolet Corvette 68-83 58.7-59.5 3655
84-95 59.6-60.4 3890
Chevrolet Camaro (Z28) 76-80 61.3-60.5 3820
Pontiac Firebird (TA) 76-80 61.3-60.5 3900
Ford Mustang II 74-79 55.6-55.8 3305
Pinto 74-79 55.6-55.8 3305
Mercury Capri 74-79 55.6-55.8 3305
Bobcat 74-79 55.6-55.8 3305
Chevrolet Monte Carlo 78-86 58.5-58.8 3235
Buick Century 78-86 59.0-58.8 3700
Pontiac Grand Prix 78-86 58.9-59.0 3735
Plymouth Volare 75-79 61.0-60.5 3395
Dodge Aspen 75-79 61.0-60.5 3395
Dodge Dart 76 59.2-55.6 3600
Table taken from "How to Build a Custom Classic Truck" Peterson Publication; June or July 1999
Written by: Don Emmons & Mike Briggs
Jim & Caroline
Great reply Jim, thanks for sharing that with us. I wish my
records were one tenth as organized as yours are. Gonna save
that one for sure.
DG
Denny G
Sandwich, IL
that one for sure.
DG
How's your hotrod AD project coming along DG?
Any blueprints drawn up yet?
Carl
When was the last time you saw a Dodge Cricket or Aspen?
Lots more pictures
In the mind Carl, in my mind.
Might have found a 261, won't know till it's torn down if its
a good one. Now all I have to do is finish a '50, a '54, turn
a horse barn into an auto shop, tend to 6.55 acres and 100
trees, paint the house, remodel the kitchen, fit two overhead
doors into the barn and then, replace the front door, replace
the back door, new screens in the screened in porch, then
paint it. Then maybe, I can start looking for the rest of
that "Not Rod".
dg
Denny G
Sandwich, IL
If you go with the 261 and put a T-5 with overdrive and a .390/.373 rear gears (thus remaining on topic for those scoring at home), you will wonder why anyone would ever put a 350 in one of these trucks!
Carl
So you can smoke the tires up of course Carl.
When and If, I ever did take the ax to one of these truck, the
first thing that I would eliminate would be the beam axle, the
second thing would be the closed drive shaft and it would seem
with the endless choices we have of rear axles and wheels that
it wouldn't be a problem.
The info Jim posted on rear axle widths should be in the tool
box of anybody thinking of replacing the rear axle with an
open one.
Of course if money is no object then you can have a new custom
axle built to your specifications and avoid the search.
DG
Denny G
Sandwich, IL
