6 members (JW51, Jon G, MRMEROTH11, Peggy M, Southerntruck, 1 invisible), 113 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
In wiggling my distributor while the engine is running I found there is a little play where the distributor sits at idle. When I rev the engine, the distributor does turn so l will assume the advance does work. Not sure if this wiggle at idle is common or not. I do have a new vacuum advance but am a little leary at pulling up the distributor, replacing the vacuum advance, and putting it back in. Solely because this is my transportation and I need it to run. And I've been fighting with the timing issue and heat issue for some time. Any encouragement and advice is welcome. Thank you
Dennis
Riding in the Passing Lane
While a little play in the linkage is not normal, it is common. If you are leary of fixing it I would leave it alone for the time being.
1972 Chevy c10 Cheyenne Super
