| | | Forums66 Topics128,066 Posts1,055,871 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | In wiggling my distributor while the engine is running I found there is a little play where the distributor sits at idle. When I rev the engine, the distributor does turn so l will assume the advance does work. Not sure if this wiggle at idle is common or not. I do have a new vacuum advance but am a little leary at pulling up the distributor, replacing the vacuum advance, and putting it back in. Solely because this is my transportation and I need it to run. And I've been fighting with the timing issue and heat issue for some time. Any encouragement and advice is welcome. Thank you
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | While a little play in the linkage is not normal, it is common. If you are leary of fixing it I would leave it alone for the time being. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
