3 members (Stewart2, 55shaker, 1 invisible),
145
Mod | | | Forums66 Topics128,165 Posts1,057,010 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 48 | OK I have a 72 c 50 the rims are 5 and 10 bolt on in center of rim. My question is can I put 8 1/4 20 tire on in place of 9 20 tires?are all the rim sizes the same? There are 10 x 20 tires also on these old trucks are those rims bigger? | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | A C50 may well have come with 8.25 tires and 9's were installed to carry a little more weight. The wheels really weren't designed for 10's and will cause the sidewalls to bulge out. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Also, if you measure the rim width or find it stamped on the rim you can compare to list of acceptable rim sizes for each tire size. In the back of the Accuride wheel catalog is this sort of general info, follow links to it in the wheel and tire tech tip. Also tire manufacturers list this info for each tire. | | | | | Joined: Sep 2015 Posts: 11 New Guy | | New Guy Joined: Sep 2015 Posts: 11 | Old rule of thumb was, you can go down a size or two no problem, if you're not getting into trouble weight-wise by doing so. Going up, you have to be really careful that the cheeks don't get close enough on the tires to rub. They WILL NOT make babies if they start rubbing their cheeks together
Bill South Texas Gulf coast 1950 Chevrolet 6400 with steel dump bedPics here | | |
