9 members (Bill Hanlon, mason86, Hotrod Lincoln, Paul Mullen, ndkid275, Hawkman, Ponchogl, wilbur53, Rusty Heaps), 85 guests, and 0 robots.
Topics128,050
Posts1,055,680
#1127689 10/03/2015 3:27 AM
I just got done rebuild rear axle. Attached is a photo showing gear contact pattern. I used baby powder. Any experts out there. How does it look? Thanks [IMG]http://i28.photobucket.com/albums/c205/levylizard/Mobile%20Uploads/image.jpeg[/IMG]]3rd member[/url]
55mater,
Not an expert, but I have set many rear axle gear sets in my 30 plus years as a mechanic. The pattern is a little hard to see, but it looks a little shallow to me. You got a good start, but need more detailed photos. Did you use a micrometer when you set it up? Did you check the backlash with a feeler gauge? Do you have the Chevrolet truck shop manual? All the specifications are in that manual.
Tim
1970 VW Beetle
H Online: Content
Since white lead has become viritually impossible to get, Prussian Blue is the best option for checking gear contact patterns. Another possibility is a tube of artist's white oil paint pigment and a few drops of linseed oil. Hold a rag wrapped tightly around the pinion flange to provide a little resistance while someone else moves the ring gear back and forth rapidly with a box end wrench on one of the attaching bolts. You'll get a much better representation of the actual contact pattern that way.
Paper mate white-out?
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
H Online: Content
Nope- - - -it needs to stay semi-liquid, not dry out so it can transfer to both gears.
Permatex Prussian Blue in a tube part# 80038. Most FLAPS have it or can get it.
Tim
1970 VW Beetle
H Online: Content
I managed to find a 5 lb. can of Dutch Boy white lead pigment on Ebay. It was about 2/3 full, but the lead carbonate paste had dried up into a solid chunk. By grinding the stuff into powder with a mortar and pestle and adding linseed oil, it goes back to the creamy paste it needs to be for checking gear patterns and also for lubricating the taper center on my lathe. Given the amount of white lead paste required for either one of these operations, I should have a lifetime supply and then some!
