0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#1127424 10/02/2015 1:22 AM
replacing a 216 engine with a 1956 235. The 235 has front motor mounts on the side. Will these work for me or will I have to drill holes to mount in the front where the 216 mounted
evac34 #1127446 10/02/2015 3:35 AM
Gas Pumper
Gas Pumper
You will have to drill holes in the front mount if they are not already there. You can choose to just drill round holes and insert the bolts from the bottom. This way you dont have to force a bolt past the timing cover risking a tear. There is a writeup on this here:
http://devestechnet.com/Home/Project1959235#timingplatemod
Of course since you do not want to tear the front of your engine down, raise it up enough to mark it properly, then drill from under. Not easy but do-able.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
evac34 #1127455 10/02/2015 4:11 AM
I have not picked up the motor yet but did notice the side mounts when I looked at it. Is it possible that the correct holes are already where they need to be Were the side brackets add one?
evac34 #1127486 10/02/2015 12:43 PM
My 58 235 has the side mounts and front mount square holes. Although I don't think it came that way from the factory and that the PO had something to do with it.
Tim
Tim
1950 3600 Some Pictures
1951 3100
1952 3100 Some Pictures
evac34 #1127580 10/02/2015 8:52 PM
Gas Pumper
Gas Pumper
I thought the ones that did not have holes already pre-drilled in the front motor mounting plate were 1958-1962. If I am right, they are already there. If I am wrong it won't take long to drill them.
The side motor mounts are useless in your Art Deco or Advance Design for mounting the motor.
Deve
The Think Tank
