4 members (SmalltownTRKGuy, Otto Skorzeny, TrknGMC, TooMany2count), 106 guests, and 8 robots.
Topics128,077
Posts1,056,032
Members48,433
#1126971 09/30/2015 12:22 AM
7
7 Offline
I have just completed a total nut and bolt restoration on my 1950 Chevrolet
1300 5 window with the original 216 engine. I am wanting to be able to drive it to shows but the 4:11 gears in rear are a pain. I know that 3:88 gears are available but rumour has it that they will only go into a U S built axle, not a Canadian built one. Is this true ?
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
7998 #1126987 09/30/2015 1:20 AM
Leo Offline
Moderator
Moderator
Never heard of that one. My truck is a US 3100, put in the 3.55 rear and am very happy with it.
Leo
7998 #1126988 09/30/2015 1:22 AM
3.55 gears?
I think you are correct about people posting something being different in Canadian trucks. Maybe it can be "solved" by using a 47-53 USA 3100 carrier?
Wait to hear from someone who has tried the 3.55 R&P in a Canadian 1300.
7998 #1126993 09/30/2015 1:39 AM
Hi, 7998, I think you mean 3:55 gears. It is true that the US gears are NOT a straight bolt in, but the US ring gear Will fit the Canadian carrier with modification. What I did was take the old 4:11 ring gear and the new 3:55 ring gear to a machine shop and have them slot the new gear to match the old gear. ( Bolt holes are on a different base circle) All the other parts will bolt in. With the drive shaft apart you should replace the front drive shaft bushing and seal assembly and the rear axle seals. I purchased the ring gear set from Patrick's in the US. Also get the speedo adapter from them. I am Very happy with change in gearing. Have Fun, Brian
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
7998 #1126995 09/30/2015 1:40 AM
7
7 Offline
Great info from all Thanks!
The comment about highway speeds requires highway brakes has got me thinking though.
All Original
