4 members (55shaker, Cosmo, Gdads51, 1 invisible),
118
Mod | | | Forums66 Topics128,069 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | What kind of little (115v) welders are you using. Does it work well? Are you doing wire feed and MIG? I would like to get a welder for doing bodywork, sheetmetal, fenders and want to keep the $$$ down. What are your suggestions?
Buddy in AK | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Hi Bud, I have a centry 125GL which is no longer made, but its a nice little MIG unit. MIGs are probably the easiest things to learn how to use. The equivalent welder now is a Hobart MIG 125 Handler. Hobart at Northern They have em at Northern, but I think sears and a few other stores carry equivalent. I don't have any special power provisions for it, and I have fixed floor boards, body panels, and even welded together an entire flatbed with it. So...I like it, other than, wire is hot all the time, so get an auto dark helmet so you don't flash yourself. Millers don't put power on the wire till triggered, so I think that puts them ahead. if you want to spend a bit more, look at HTP. If I hadn't gotten the Century as a gift, I would have bought an HTP. Click me to get to the truck pictures | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | I bought my welder from Snap-On in '88. I've never been shy about using it. It's gotten quite a workout. It's a 115v MIG. It only powers up when the trigger is pulled. I've welded miles with this thing, and, it's held up all these years. Snap-On actually delivered my new plasma cutter today. Can't wait to try that thing out!!
JS | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I'm happy with my Lincoln Mig-Pac 135, it works really well and is easy to use. I paid $400 for it three years ago.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I picked up a Lincoln weld-pak 3200HD (135) off ebay about a year ago and have been very pleased with it. I just moved from using flux core to gas and have started the sheet metal welding. I believe I sniped mine for about $280 plus shipping. The other small 110v welders are probably just as good but they seem to be more expensive.
I have also seen these in Home Depot for about $450. It is one of those tools that you are better off buying than renting, and like a cutting rig, is hard to get by without unless you have someone do it for you. Use the nozzle dip though to keep from plugging the tips.
I would also add that the Clarke brand of welders available through places like Harbor Freight may not be the best option. Their reliability has been suspect and you do not want to have your welder crap out in the middle of a project. | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | We have Miller 135's where I work (five of them) and they work out very well. With gas of course!
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Thanks for the input,
I've looked at a few bottom end ones and the BIG names. Talked to a few buddys (including you guys)that weld and think I'll save a couple more $$$ and get the Lincoln 135 Plus. I want something that will last and will be my portable unit someday if I get a big rig.
Later, Buddy in AK | | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Hard to beat the lincoln mig 135 with the bottle and price. | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I use a Century (not sure of model #) mig welder that I bought from Sam's Club. Many spools of wire and bottles of shield gas have gone through that thing. Piewagn, I want that plasma cutter! | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Gotta do my rockers & 1/4's first!! Should make this job alot easier!!
JS | | | | | Joined: Mar 2004 Posts: 44 Member | | Member Joined: Mar 2004 Posts: 44 | Just drew my first arc yesterday with the new machine (Lincoln Weld-Pak 3200HD). Tickered with repairing some cracks on one of the BBQ pits. After a couple of test runs, ran like a charm. I haven't drawn an arc in over 20 years (an it was rod type) and I took right to it. Never used a MIG before an I definitely love it. A little more practice and I'll take her to the panel truck. 1954 Chevy 3100 Panel Truck 2004 GMC Yukon 2002 Chevy 1500 4X4 "Those who expect to reap the blessings of freedom, must, like men, undergo the fatigues of supporting it." Thomas Paine, The American Crisis, No. 4, September 11, 1777
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Great feeling, isn't it? Now go get an autodark helmet and wonder how you ever did without it.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2003 Posts: 7 Member | | Member Joined: Apr 2003 Posts: 7 | I've been using my own Weld-Pak 100 on the job for a few years and it welds great....told the boss he should get a Weld-Pak 3200 HD so we would have less splatter, he agreed but suggested I needed to store it in my shop....shucks...I guess if I have to...
'52 2-ton Loadmaster COE....... ( This Space For Rent )
