3 members (RoadsScholar, moparguy, 51sub), 102 guests, and 3 robots.
Topics128,070
Posts1,055,892
Members48,428
#112673 05/25/2004 11:10 PM
What kind of little (115v) welders are you using. Does it work well? Are you doing wire feed and MIG? I would like to get a welder for doing bodywork, sheetmetal, fenders and want to keep the $$$ down. What are your suggestions?
Buddy in AK
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
#112674 05/25/2004 11:52 PM
Hi Bud,
I have a centry 125GL which is no longer made, but its a nice little MIG unit. MIGs are probably the easiest things to learn how to use. The equivalent welder now is a Hobart MIG 125 Handler.
Hobart at Northern
They have em at Northern, but I think sears and a few other stores carry equivalent. I don't have any special power provisions for it, and I have fixed floor boards, body panels, and even welded together an entire flatbed with it. So...I like it, other than, wire is hot all the time, so get an auto dark helmet so you don't flash yourself. Millers don't put power on the wire till triggered, so I think that puts them ahead. if you want to spend a bit more, look at HTP. If I hadn't gotten the Century as a gift, I would have bought an HTP.
Click me to get to the truck pictures
#112675 05/26/2004 1:09 AM
I bought my welder from Snap-On in '88. I've never been shy about using it. It's gotten quite a workout. It's a 115v MIG. It only powers up when the trigger is pulled. I've welded miles with this thing, and, it's held up all these years. Snap-On actually delivered my new plasma cutter today. Can't wait to try that thing out!!
JS
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
#112676 05/26/2004 4:35 AM
I'm happy with my Lincoln Mig-Pac 135, it works really well and is easy to use. I paid $400 for it three years ago.
Paint & Body Shop moderator
#112677 05/26/2004 4:52 AM
Anonymous
Unregistered
Anonymous
Unregistered
I picked up a Lincoln weld-pak 3200HD (135) off ebay about a year ago and have been very pleased with it. I just moved from using flux core to gas and have started the sheet metal welding. I believe I sniped mine for about $280 plus shipping. The other small 110v welders are probably just as good but they seem to be more expensive.
I have also seen these in Home Depot for about $450. It is one of those tools that you are better off buying than renting, and like a cutting rig, is hard to get by without unless you have someone do it for you. Use the nozzle dip though to keep from plugging the tips.
I would also add that the Clarke brand of welders available through places like Harbor Freight may not be the best option. Their reliability has been suspect and you do not want to have your welder crap out in the middle of a project.
#112678 05/26/2004 5:15 AM
We have Miller 135's where I work (five of them) and they work out very well. With gas of course!
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#112679 05/26/2004 7:07 PM
Thanks for the input,
I've looked at a few bottom end ones and the BIG names. Talked to a few buddys (including you guys)that weld and think I'll save a couple more $$$ and get the Lincoln 135 Plus. I want something that will last and will be my portable unit someday if I get a big rig.
Later, Buddy in AK
'50 GMC Suburban
#112680 05/26/2004 7:31 PM
Hard to beat the lincoln mig 135 with the bottle and price.
#112681 05/26/2004 8:03 PM
I use a Century (not sure of model #) mig welder that I bought from Sam's Club. Many spools of wire and bottles of shield gas have gone through that thing. Piewagn, I want that plasma cutter!
#112682 05/27/2004 4:20 AM
Gotta do my rockers & 1/4's first!!
Should make this job alot easier!!
JS
#112683 05/30/2004 2:30 AM
Just drew my first arc yesterday with the new machine (Lincoln Weld-Pak 3200HD). Tickered with repairing some cracks on one of the BBQ pits. After a couple of test runs, ran like a charm. I haven't drawn an arc in over 20 years (an it was rod type) and I took right to it. Never used a MIG before an I definitely love it. A little more practice and I'll take her to the panel truck.
1954 Chevy 3100 Panel Truck
2004 GMC Yukon
2002 Chevy 1500 4X4
"Those who expect to reap the blessings of freedom, must, like men, undergo the fatigues of supporting it."
Thomas Paine, The American Crisis, No. 4, September 11, 1777
#112684 05/30/2004 5:44 AM
Great feeling, isn't it? Now go get an autodark helmet and wonder how you ever did without it.
#112685 06/12/2004 5:51 AM
I've been using my own Weld-Pak 100 on the job for a few years and it welds great....told the boss he should get a Weld-Pak 3200 HD so we would have less splatter, he agreed but suggested I needed to store it in my shop....shucks...I guess if I have to...
'52 2-ton Loadmaster COE....... ( This Space For Rent )
