0 members (),
82
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 9 New Guy | | New Guy Joined: Nov 2010 Posts: 9 | I have a 52, 3800 1.5 ton.. It "seems" LMC carries the 1/2 and 3/4 ton king pin sets, but they won't work in a 1.5 ton.. Does anyone have any info on when I can find them?
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Mole, Try using the search function. I know this topic has came up at least a few times in the past. Seems like a good Napa person will be able to find the parts, but you will need to bring in the old parts. You will also need a reamer to run in the bushings after you install them.
Welcome to the Stovebolt
| | | | | Joined: Nov 2010 Posts: 9 New Guy | | New Guy Joined: Nov 2010 Posts: 9 | Thanks RDomeck.. I'm wondering if the 1/2 or 3/4 ton is the same as the 1.5 ton pins.. I now know the 53 pin is too long, which is what I got from LMC... I'll search some more  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Here are specs/dimensions from the Shop Manual Check not only the diameter of the pin, but also the outer-diameters of the bushings. | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I believe if you read through Griggs sticky post at the top of this section you will find some info on the king pin sizes. The king pin sizes will be different on these bigger trucks. I'm just not up to speed on all the different sizes. | | | | | Joined: Nov 2010 Posts: 9 New Guy | | New Guy Joined: Nov 2010 Posts: 9 | I'll check that sticky out.. Thanks for all the info guys | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Also if you have a truck spring shop locally you could check with them. I purchased my set, 3/4t, from a local shop. Hope this helps . Have fun and good luck Dan | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 3800 is a 1 ton, and should use same king pin as 3/4 ton. (From memory 0.9something" kingpin diameter) 4400 or 4100 may also have same axle beam as above but uses 5 lug hubs, same King pin as above. (Exception listed below)
6100 and 6400 have heavier axle, 1.109" kingpin, and was a heavy duty option on the 4000 series 1.5 ton.
Napa is an easy source for all king pin kits in question. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Mole, As Grigg stated, a 3800 series truck, is a 1 ton truck. 3100 = 1/2 ton, 3600 = 3/4 ton, 4100 = 1 1/2 ton, 4400 = 1 1/2 ton, 6100 = 2 ton, 6400 = 2 ton, & 6500 = long wheelbase 2 ton. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 |
| | | | | Joined: Nov 2010 Posts: 9 New Guy | | New Guy Joined: Nov 2010 Posts: 9 | Napa just found me one.. Thanks for all the help guys!!
