| | | Forums66 Topics128,277 Posts1,058,448 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 20 Apprentice | | Apprentice Joined: Nov 2007 Posts: 20 | Does anyone have a source for replacement clutch fork boot. Seems the 55-59 chevy truck may not be reproduced. I have checked many catalog companies and local transmission sources as well. They are available for years in 60's up. Any suggestions?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | depends on the engine/bellhouse, not just year - for the 235, a later one can be adapted, my original was [is] leather - for the V8, most later ones should fit right in
Bill | | | | | Joined: Nov 2007 Posts: 20 Apprentice | | Apprentice Joined: Nov 2007 Posts: 20 | Lack of info. It is a 235 6 cylinder. Mine was leather also. So the later years works, is there any modification needed? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not sure how much cutting you'll have to do, but I have seen a couple 235's with rubber boots - measure the hole and see how close to that you can get, most likely there will be a bit of fitting, but ya gotta do what needs to be done eh? if you still have an original, you could even try making another of leather, I thought it looked pretty straight forward
Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | The after-market vendors show this boot. I bought one of the rubber ones they have but it doesn't fit. What does the original look like?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The reproductions iv,e bought never fit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I made one of those rubber ones fit. A little grinding on the bellhousing to make a lip for it secure against, then I cut a plate out of 1/8" aluminum plate, drilled 6 holes for 6-32 machine screws to retain it. Worked like a charm.
Bill Burmeister | | | | | Joined: Nov 2007 Posts: 20 Apprentice | | Apprentice Joined: Nov 2007 Posts: 20 | Thanks, i'll look at doing that. I may trim some up like red 58 recommended. | | | | | Joined: Dec 2014 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 66 | Member Oldbluetruck was wondering what the original clutch fork boot looks like. Today I was doing some prep work in advance of a trans/clutch swap and pulled out my original leather boot. Hopefully the picture link will work OK. I read where Bow Tie Bits offers an accurate replacement, although I have no 1st hand knowledge if this is true. A little needle and thread work and I'm good for another 50 years I think. Sometimes you just can't beat natural materials! Misc. Part Details
'59 Apache ‘21 Beta 390RS ‘18 BMW R1200RT '12 Ford Flex '13 Aprilia Tuono ‘11 Ducati Hypermotard Salisbury, MD
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Like to see it, but...your shutterfly account must be set up private, it wants us to log in to see your pictures.
dg
Denny G Sandwich, IL
| | | | | Joined: Dec 2014 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 66 | Try it again, I think I've fixed it. I gotta get better at this picture thing.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Got it that time. I've seen those on a lot of engines, mostly all oil and grease soaked and falling apart. I've also seem a more engines that did not have them. The parts books list no less than nine part numbers over the years. Odd as it may seem, the boot is listed in the 30's parts books, but then the group is missing during the Advance Design years and shows up again in 1955 and later books. There is another gap between 1957 and 1960 when they show up again thru 1969 as 'black rubber'. Here are more examples with more part numbers: http://www.4speedconversions.com/clutch-fork-boots I can't find anyone that is reproducing them. dg
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | MikeB, I have an original one of those on my V8 bell housing. I also have a leather one I took off a 6 cyl. I just had an idea....My old boot is dry and I'm going to take it to an upholstery shop and see if they can't make me a new one.
1959 3100 Apache Fleetside
| | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | As long as you have the spring wire clip making a new leather boot will be easy. See if the local horse tack shop has any scrap leather and sew it by hand yourself. Mike B  | | |
