| | | Forums66 Topics128,125 Posts1,056,337 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 52 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 52 | Looking for the diameter dimension of the circular hub at the back of a 54-55 steering wheel.From looking at pictures this looks to be the same as the diameter of the top of the steering column?
Thanks | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | About 4". The housing would be replace when equipped with the optional directional signal accessory housing/switch.
dg
Denny G Sandwich, IL
| | | | | Joined: Sep 2013 Posts: 52 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 52 | I wasn't aware there was a hub without a signal accessory - from the pics I've seen, with or without, the hubs look pretty much the same dimension-wise - about 4" | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here are instructions for the steps to replace original/standard parts with the turn-signal parts (steering-wheel/column-related parts): illustration 1 see Denny's post for the turnsignal cup assembly (a lever will be needed) illustration 2 switch cancellor illustration 3 | | | | | Joined: Sep 2013 Posts: 52 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 52 | Great "how-to" pics - very helpful.
Thanks gents! | | |
