Brrrr
place holder
2 members (Peggy M, MTD91), 141 guests, and 0 robots.
Topics128,274
Posts1,058,432
Members48,489
#1126336 09/26/2015 1:14 PM
Lubricant was dripping out from under the Blue Funk like someone pouring syrup on a pile of pancakes. I removed the flywheel under pan and took this pic:
http://s837.photobucket.com/user/daveydouglas/media/broke%20tran%203.jpg.html?sort=3&o=0
Please keep in mind that I know next to nothing about transmissions, only what I picked up from checking out the Sop Manual...
Is that broken off portion the front of the transmission case or is it the clutch gear bearing retainer?
And any other input is welcomed.
Thanks!
Edit: fixed link
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
Davey Do #1126381 09/26/2015 7:28 PM
Can't see what's broken from the blurry picture.
I hope there isn't a puddle pouring out from under your camera or computer. smile Both of those particular items cause me eternal frustration.
Carl
Davey Do #1126417 09/26/2015 10:24 PM
It looks like the snout where the throwout bearing slides is broken off the bearing retainer. Was the transmission loose on the bellhousing? That's usually the cause of the retainer breaking there.
Thanks Jerry. I wonder if the original cause wasn't the big rig that T-boned the Blue Funk Back in '11. Remember?
I noted when I removed the flywheel under pan the rear two mounting screws did not line up with the holes in the cross member.
Dave
Davey Do #1126490 09/27/2015 3:49 AM
Since that incident resulted in a bent frame right in that general area, it's almost certainly the cause. Fortunately, those bearing retainers aren't particularly scarce. If you're still running the torque tube 3 speed, I've got a couple of complete transmissions stashed away. Let me know if you need one.
Davey Do #1126518 09/27/2015 8:15 AM
Thanks again, Jerry!
PM to be sent!
Dave
Davey Do #1138545 12/09/2015 8:50 AM
As an end note: the tranny was removed and the bearing retainer was replaced with one Jerry located on ebay.
A couple of notes: The Shop Manual said the steering wheel grommet needed to be moved. It did not. It also said the battery needed to be removed. It did, but only to be able to get to the bolts holding the cross member to the passenger side frame rail. However, no mention was made of removing the cross member, which we did in order to drop the tranny.
However, the Blue Funk is back on the road without a leaking tranny with a Big Thanks to Jerry and my stepson-in-law Tim!
Dave
