7 members (TooMany2count, Wheelie, Stovebolt48, Napco Mark, baldeagle, RaNfLaS, Jeff Ogden), 72 guests, and 7 robots.
Topics128,021
Posts1,055,346
Members48,420
#1126400 09/26/2015 8:39 PM
This u-joint doesn't look like the one in my 38 Chevy shop manual for a 1/2 ton. It looks a little more beefy like the one on 3/4 or 1 ton judging by the figures in the manual. Does anyone know if this is correct for a half ton?
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
Hoff #1126598 09/27/2015 11:21 PM
According to What I can find, that is a 1940-1953 U joint. 1933 to 1939 are "open" drive shaft and the U joint looks more like a modern one. So I looked at the manual...and it looks like a torque tube to me. http://chevy.oldcarmanualproject.com/shop/1938/38csm086.html
And that would be just like what you have in the picture. So further looking got me to here: http://www.vapinc.com/chevy/Universal%20Joints%20and%20Parts/main.html I think this is the folks that make the parts every one is selling. Might be worth a call for more information.
Some one here will know what I am guessing. I hope you get some better information than I was able to find.
Steve H
Hoff #1126651 09/28/2015 4:01 AM
Thanks Steve. The figure in the manual seems to show that mine is like the one in the bottom illustration. I'm in the process of taking my driveline apart, and want to make sure I know what I've got before I start ordering parts. I'll definitely check with the sources you provided. Thanks again.
Hoff
1938 Chevy 1/2-ton
Hoff #1128751 10/10/2015 12:56 AM
Okay, so I'm not sure how they got this in to begin with... I'm trying to disconnect the u-joint. It looks like a u-joint for a 3/4 ton, and I'm driving the bushings out of the yoke like the manual says. The problem is that there's not enough clearance to fully drive the bushings out before they contact the transmission housing.
pic 1
pic 2
I can only drive them about halfway out. On the 3/4 ton, the transmission housing has some cutouts that allow the bushings to be driven out as shown here . On my half-ton, the transmission housing doesn't have those cutouts.
So, how do I get the driveshaft out if I can't take the u-joint apart? Do I need to pull the rear end leaving the u-joint connected to the transmission? Is that even possible?
1938 Chevy 1/2-ton
Hoff #1128761 10/10/2015 1:30 AM
With your setup it looks like the only option is to pull the diff back. Then you can reach down the center of the u' joint with a 9/16" socket and remove the center bolt and whole u' joint assembly.
My Blog
